Problems generating Binary Files with STM32CubeIDE & System Workbench
2019-09-12 10:36 PM
I have added the following command to the post build steps.
arm-none-eabi-objcopy -O binary "${BuildArtifactFileBaseName}.elf" "${BuildArtifactFileBaseName}.bin"
The size of .bin file generated is 393411KB compared to 383KB hex file and does not upload with STM32 Cube Programmer.
Has anyone been able to successfully generate a binary file (.bin) to program the STM32WB and how have you done so?
Thanks,
Daniel
- Labels:
STM32CubeIDE
STM32WB series
2019-09-12 11:59 PM
Hello @Daniel L ,
This is a known issue also present inside the firmware package until STM32Cube_FW_WB_V1.2.0. This is corrected inside STM32Cube_FW_WB_V1.3.0 coming.
I enclose here the .s and .ld containing the correction while waiting the official release.
2019-09-12 11:59 PM
Hello @Daniel L ,
