2023-03-17 01:57 AM
Good morning everyone,
I'm using NUCLEO-WL55jc1 board and STM32CubeIDE 1.10.1. The case is that before creating a new second project, the ST-LINK V3 was detected and everything worked properly. However, currenly, when I want to debug the program I get this message (even with the first project I have, LoRaWAN_End_Node example).
I hope someone could help me.
Thank you very much,
Carlos
2023-03-17 02:37 AM
Hello @CLled.1
I reproduce your issue at the beginning i see the same error message "No ST-link detected! Please connect ST-LINK and restart debug session"
I simply change the cable port and then everything is working fine:smiling_face_with_smiling_eyes:
So try to do the same thing and tell me what's up !
Thanks,
wijeden,
2023-03-17 02:10 AM
In addition, I should mention that the LoRaWAN_End_Node example is still running as I could see on Tera Term.
2023-03-17 02:37 AM
Hello @CLled.1
Thanks,
wijeden,
2023-03-17 01:51 PM
Hello @Wijeden RHIMI ,
I have done what you told me and everything works perfecty again! I really appreciate your help.
Carlos
