Missing CO2 ZCL cluster in Zigbee library
I have started project with NUCLEO-WB55RG, which i planned to use as Zigbee router for my Home Assistant. I have manage to get temperature working, then I wanted to add CO2 value (measured by SDC30 sensor) as next step but i have found out that CO2 cluster is missing from ZCL headers files provided by ST. So my question is: Does ST provide more up-to-date ZCL Cluster library or it is it possible to implement ZCL cluster for CO2 myself? Or there is some other solution?
Thanks for any advice.
