2025-04-17 3:13 AM
Hi Team,
I am facing some issues with the LoRaWAN MAC layer version 1.0.4. I have registered and called the store context function, but I am still having trouble switching the end nodes in the TTN server. Additionally, I am receiving a "devNonce is too small" error when trying to connect the same end node a second time. The first attempt works fine, but I encounter this devNonce error on the second attempt ( or )Sometimes, it takes five minutes to connect to the same end node a second time.. Is this a security feature or a bug? Please confirm on your side.
Thank you.
2025-04-17 3:26 AM
@kRaje.1 wrote:I am receiving a "devNonce is too small" error .
Where do you receive that - on the device, or on the TTN console?
Might also be worth asking on the TTN forum: https://www.thethingsnetwork.org/forum/
eg, DevNonce is too small - what to do?
(don't forget to give links when cross-posting)
2025-04-20 10:42 PM - edited 2025-04-20 11:53 PM
In the TTN console, I am receiving a "devnonce is too small" error. My devnonce counter value increments each time I send a join request, but I am still facing this "devnonce is too small" issue.
