2022-11-13 09:09 AM - last edited on 2023-11-30 07:05 AM by Amel NASRI
Hi.
I am working on STM32WB55 and I need to implement a digital signature verification function. I know this MCU has PKA for this purpose, but I also found that ST produce STSafe-a100 module, that in my understanding does about the same, at least for my use(ECDSA).
So the question is, what is the difference between those module and do I need this STSafe-a100 in my device?
Appreciate any tip.
Thanks.
2022-11-22 03:00 AM
Hi @YWor.1
Thanks for you request.
The added value of the STSAFE-A solution is to have smartcard grade Secure Element to manage ECC private key to generate ECDSA signature and a secure storage.
In your use case, you just need to verify an ECDSA signature if I have understood well, therefore the STSAFE-A will act as a crypto accelerator like the PKA from the STM32WB55.
The added value of the STSAFE-A in your use case could be to store in a secure way the public key you use for ECDSA verification. In that case, the STSAFE-A could guarantee the integrity of the public key if set in a read-only region.
Best Regards,
Benjamin
