I am unable to connect the microcontroller to STM32CubeProgrammer, Keil, or other software via ST-Link
‎2024-12-14 5:08 PM
In order to test the BLE performance of the STM32WB55CGU6 in STM32CubeMonitor-RF, I downloaded the BLE_TransparentMode program onto the STM32WB55CGU6. However, I did not notice that the pin configuration of this program did not enable Serial Wire. The pin configuration is shown in the image.
This has resulted in a problem: I am unable to connect the microcontroller to STM32CubeProgrammer, Keil, or other software via ST-Link. I have also tested the UART and USB connections in STM32CubeProgrammer, but they also failed to connect. What should I do to resolve this issue?
BLE
STM32WB series
‎2024-12-15 12:53 AM
SWD is always enabled under reset. Switch connection mode to this.
‎2024-12-15 6:21 AM
If NRST is connected to the debugger, use "Connect Under Reset"
You can also use BOOT0 pin to stop your broken code from running and blocking access.
