How to setup STM32WB timer to 1500kHz?
MM..1
Chief II
Exist some internal way to do this ? Itry this , but clock config for CPU2 must be 32MHz ...
Unfortunately, is not possible to do that.
Best Regards
4 REPLIES 4
Remy ISSALYS
According to the following formula for PWM frequency, there is no possibility to reach a frequency of 1500 kHz.
0693W00000QO4TdQAL.pngThe closest frequency which can be setup is 1,52381 MHz with F_tim = 32 MHz, PSC = 0 and ARR = 20.
Best Regards
CPU1 timer is clocked 64 and this formula is source for question.
I mean A is possible change clock to other value?
B is way to generate 1,5M to pin , then connect back to timer clock input...
Best Regards
In other companies people make frequency generators with phase adders / accumulators, ie NCO/DDS
These are incredibly simple and flexible, got ASICs from the 1990's using this technique for accurate/flexible baud rate generators.
