How to create a new (and very simple) STM32WL project from scratch ?
JChau.2
Hi everyone,
I'm trying to convert our IoT Sigfox sensor from EFM32 to STM32 architecture.
As a beguinner on STM32, I'm using an LSM100A eval board based on STM32WLE5CC.
Can anybody explain me how to create a simple Sigfox project ? I just want to send a simple Sigfox message.
I try to start from the PushButton skeleton available on project configuration but there is alway something missing in the generated source code. First build give errors like these :
../Core/Src/timer_if.c:337:51: error: 'RTC_N_PREDIV_S' undeclared (first use in this function); did you mean 'RTC_PRER_PREDIV_S'?
../Core/Src/timer_if.c:415:30: error: 'RTC_PREDIV_S' undeclared (first use in this function); did you mean 'RCC_PLLDIV_3'?
Any help would be greatly appreciated !
Thanks,
Johann
Louis AUDOLY
You can find a ready to use project with sigfox by downloading the software pack here :
 https://www.st.com/en/embedded-software/stm32cubewl.html
Under "STM32Cube_FW_WL_V1.2.0\Projects\NUCLEO-WL55JC1\Applications\Sigfox\Sigfox_PushButton" you will find a working project on Sigfox.
Hope it helps
Louis AUDOLY
Hope it helps
JChau.2
Thanks a lot for your answer. I already downloaded the software pack but there is no Sigfox folder in Applications.
I just want to make the minimal app, like a Sigfox hello world but I don't find any document to explain how to configure the project, pinout, clock, includes, ... from an bare empty STM32 project.
Is there any resource somewhere I didn't see ?
Thanks.
Johann
Check the NUCLEO-WL55JC1 folder, not NUCLEO-WL55JC.
Rgds,
Laurent
