2023-08-29 06:26 AM - edited 2023-08-29 06:33 AM
I would like to program the NUCLEO-WL55J1 as a w-MBus concentrator. Getting data from nearby w-MBus sensors and pass it on to the cloud, while I still have the option to switch to LoRa for data transmitting.
Do any of you have an example project, or any guides how to do this.
2023-08-29 12:42 PM
2023-08-29 07:23 AM
Hello @TA.1
I suggest you to take a look at the exemples of the wM-Bus in the X-CUBE-SUBG1. And then try to adapt it to the STM32WL55JC1 using the AN5408.
Hope this is helpful. If this answers your question, please check it as best answer to be diffused.
Best regards.
II
2023-08-29 12:42 PM
2023-09-06 06:54 AM
Thank you.
The best way is to buy the stack from Stackforce.
Please see this post. https://community.st.com/t5/stm32-mcus-wireless/setting-up-the-radio-to-sniff-raw-wireless-m-bus-packages/td-p/588367
