STM32WL5MOC bootloader mode
‎2025-01-20 2:39 AM - last edited on ‎2025-01-20 2:52 AM by STTwo-32
I'm looking for advices to place the module STM32WL5MOC in bootloader mode from different methods :
- Through BOOT0 and NRST but I can not find the communication interface that I can communicate with (for example UART) this specific mcu in the application note AN2606.
- Also, I'm interested to know how can I access to the new firmware stored in the External memory flash for firmware update as the flash that is in the dev board B-WL5M-SUBG1 using as an example.
- Is it possible to place this module in bootloader mode in the software if I can not have access to the BOOT0 and NRST from an external device that can control it?
- Any example to do FUOTA point to point if I want to use the SubGHz modulation and not LoRaWAN server?
- Labels:
STM32WL series
‎2025-02-24 5:42 AM
Hello @User2501
- The STM32WL5MOC is a module based on the STM32WL55JC. So, you can find all details on boot operation for this module on the chapter 84 of the AN2606.
- Unfortunately, there is not such an example on a board that include the STM32WL.
- Follow the Pattern 13 of the table 2 of the AN2606 to know how to that.
- There is not a P2P FUOTA application, you can use the LoRaWAN implementation and try to build your own in a P2P context.
Best Regards.
STTwo-32
‎2025-02-24 5:42 AM
Hello @User2501
Best Regards.
STTwo-32
