Hello everyone, I have the flash memory AT25SF321B and I want to write and read it. As a µC I use an STM32WB55. I write some values but if i read it back i get only zeros. But i can read the manufacture id 1F 87 01. Hope you can help me.
Donkanaille
// 25AA040A instructions
      const uint8_t EEPROM_READ = 0x03;    // 03h Normal Read Data
      const uint8_t EEPROM_WRITE = 0x02;  // 02h Page Program
      const uint8_t EEPROM_WRDI = 0x04;   // 04h Write Disable
      const uint8_t EEPROM_WREN = 0x06;   // 06h Write Enable
      const uint8_t EEPROM_RDSR = 0x05;   // 05h Read Status Register
      const uint8_t EEPROM_WRSR = 0x01;   // 01h Write Status Register
      const uint8_t EEPROM_RDSR2 = 0x35;  //  Read Status Register 2
      const uint8_t EEPROM_RDSR3 = 0x15;  //  Read Status Register 3
      const uint8_t RESETENABELE = 0x66;
      const uint8_t RESETDIVICE = 0x99;
      const uint8_t CHIPERASE = 0x60;
      const uint8_t ID = 0x9F;
      const uint8_t ERASE = 0x44;
      const uint8_t BLOCKERASE = 0x20;
       // Variablen
       char spi_buf[20];
       uint8_t addr[3];
       uint8_t wip;
    // CS pin should default high
        HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_SET);
        // Enable write enable latch (allow write operations)
        HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_RESET);
        memStat = HAL_SPI_Transmit(&hspi1, (uint8_t *)&EEPROM_WREN, 1, 100);
        // Read status register
        memStat =  HAL_SPI_Transmit(&hspi1, (uint8_t *)&EEPROM_RDSR, 1, 100);
        memStat =  HAL_SPI_Receive(&hspi1, (uint8_t *)spi_buf, 1, 100);
        // Test bytes to write to EEPROM
        spi_buf[0] = 0xBB;
        spi_buf[1] = 0xCD;
        spi_buf[2] = 0xEF;
        // Set starting address
        addr[0] = 0x05;
        // Write 3 bytes starting at given address
        HAL_SPI_Transmit(&hspi1, (uint8_t *)&EEPROM_WRITE, 1, 100);
        HAL_SPI_Transmit(&hspi1, (uint8_t *)&addr, 3, 100);
        HAL_SPI_Transmit(&hspi1, (uint8_t *)spi_buf, 3, 100);
        // Clear buffer
        spi_buf[0] = 0;
        spi_buf[1] = 0;
        spi_buf[2] = 0;
        // Wait until WIP bit is cleared
        wip = 1;
        while (wip)
          // Mask out WIP bit
          wip = spi_buf[0] & 0b00000001;
        // Read the 3 bytes back
        HAL_SPI_Transmit(&hspi1, (uint8_t *)&EEPROM_READ, 1, 100);
        HAL_SPI_Receive(&hspi1, (uint8_t *)spi_buf, 3, 100);
0693W00000QKzvlQAD.png0693W00000QKzwAQAT.png0693W00000QKzw5QAD.png0693W00000QKzsUQAT.png0693W00000QKzm6QAD.pnghttps://www.mouser.de/datasheet/2/590/AT25SF321B-1635166.pdf
Here is an tutorial i used. The difference to my memory is the 24bit adress length.
https://www.digikey.com/en/maker/projects/getting-started-with-stm32-how-to-use-spi/09eab3dfe74c4d0391aaaa99b0a8ee17
2 REPLIES 2
Probably need to make sure the transmit actually completes before releasing CS
Use the TransmitReceive form, push out dummy bytes where you need clocks, and discarding returned data where it's purely an output.
Donkanaille
i inserted some HAL_Delay to wait after transmitting but this doesn´t helped.
Where is the difference between TransmitReceive and single use of Transmit and Receive?
The weird thing is it worked a few month ago. But the chip should be okay, because i can read the manufactor Id. Perhaps i accidentally changed some settings or its a timing problem.
The 24 bit used for the adress should be alright too. I first used the example vom digikey, but he used 8 bit for the adress what didnt work.
