2021-02-15 01:59 AM
2021-02-17 05:42 AM
how could i found problem any log maybe i have problem on laptop ? maybe any restricted issue ?
2021-02-17 05:46 AM
i install ide from scratch also java ( jre jdk ) still the same problem
the workaround doesn't work after the steps i am trying generate code i get following error
2021-02-17 08:51 AM
Working fine on my side too.
Could you share where is your firmware packs repository (Preference windows below snapshot like).
Could you have a try promoting another workspace repository. Sounds you're relying on default what's good but to help figuring out what's not ok if your local env may help to have an extra try.
2021-02-17 09:30 AM
Possibly share .*log* as part of your workspace .metadata folder ....
Based on your .ioc file I'm able to reproduce from time to time your issue .... (not systematic so) but if failing getting some weird trace within such log files ... such may help ST to dig into issue I guess
2021-02-18 01:29 AM
Hi @Albatross,
I can't reproduce the issue (tested with 3 Windows 10 PCs).
What I recommend:
I'm waiting for your feedback,
Aymen.
2021-02-18 04:33 AM
i dont kmow what to do
it is not working on my laptop etiter any project on stm32cubeide
2021-02-18 05:34 AM
Strange behavior !
In this case I will give you the way to delete all your preference, may be some corrupted data are remaining in environment, please do:
In this way, you will get a fresh environment.
If issue reproduced, please zip and send us the C:\Users\<user-name>\STM32CubeIDE\workspace_1.5.1 folder.
Regards,
Aymen.
2021-02-18 07:33 AM
it falied
see attached share link to workspace
https://drive.google.com/file/d/1OGhNQFrk2_FhZxxLXeBx-GAuuQjbOaWs/view?usp=sharing
2021-02-18 08:31 AM
Looking at your log, nothing that help to catch the issue. But let's look for another way:
Hope this will work !
