Example for GPIO control using DMA and PWM.
‎2023-11-16 8:42 AM - edited ‎2023-11-16 8:44 AM
I want to change the DMA memory according to the PWM signal and change the GPIO pin to turn on/off automatically based DMA memory information.
Are there any good examples of this?
STM32WB series
‎2023-11-16 10:59 AM
It was in the top-10 search results "GPIO DMA" on this board:
‎2023-11-16 8:48 AM
Hello @KKIM.6,
Could you provide more details maybe?
‎2023-11-16 9:00 AM
My microcontroller has 48 GPIO pins and I want to turn on and off each GPIO pin when 1 MHz PWM signal.
Only One GPIO pin should be turned on once and the other GPIO pin should be turned off.
The reason I need to use DMA is that, In the case of HAL code, the on/off function speed of GPIO is around 1 ms not 1 us (1 MHz).
So, I want to assign on/off of GPIO to a DMA and the PWM value change the DMA of GPIO pin.
