Does LoRaWAN_AT_Slave example code save the configured values to the NVM(Non-volatile Memory) ?
ksrav.1
Hi ,
 I was using LoRaWAN_AT_Slave example code for NUCLEO-WL55JC1 Board on STMCUBEIDE .
AT command response was OK but , the configured values are not getting stored into flash (upon reset getting the default values)..
CONTEXT_MANAGEMENT_ENABLED and MAX_PERSISTENT_CTX_MGMT_ENABLED are disabled by default . By enabling these flags i am getting "error: unknown type name 'NvmmDataBlock_t'" and few more errors.
am i missing any configurations?
Reference doc : https://www.st.com/resource/en/application_note/dm00699239-lorawan-at-commands-for-stm32cubewl-stmicroelectronics.pdf
Thanks.
FYASA.1
I have same issue. There is no documentation or guideline about this.
Did you find a any solution ?
YBOUV.1
this feature is not yet available.
Best Regards
RGira.1
Is there another method to save and restore a OTAA session between resets or is this feature strictly required?
