Class C downlink not working in STM32WL55JC2.
‎2023-08-03 9:46 PM
- My STM32WL55JC2 is programmed with the example code for Lora End Node given in the SDK v1.3.0.
- Class_A is enabled by default and working properly i.e. receive window of the MCU opens only after the periodic uplink.
- When the class is set to Class_C in the LmHandlerConfigure(&LmHandlerParams) function, it still functions like a Class_A device.
- I also tried to change the class later in the join request, but that was also unsuccessful.
Any suggestions?
LoRa
STM32WL series
‎2023-08-03 11:48 PM - edited ‎2023-08-03 11:57 PM
Hello @RonNad14 and welcome to ST Community.
I suggest you to take a look at the application notes AN5481, AN5406 and AN5554. You will find what you need to solve your Class C problem.
Best Regards.
Issam
‎2024-03-07 5:11 AM
I am facing the same issue as the @RonNad14 . Even though I have changed default LoRa class into 'class C', STM32WL55JC1 still behaves as the 'class A' device.
I tried to change class of the device from the Termite, but didn't have any success.
Has anybody found the solution for this problem?
Thank you in advance!
‎2024-07-16 10:56 AM
Hi @RonNad14,
I am also facing the same issue with STM32WLE5CCU6 controller.
Anyone please rectify this problem.
Thank you.
