2025-01-13 09:52 AM
Can the 433 MHz STM32WL55JC2 operate at 915 MHz by changing the antenna and software configuration?
I have the STM32WL55JC2 functioning at 433 MHz. I'm studying signal propagation and want to operate this device at 915 MHz. I know there is a difference in antennas, but can I swap in the 915 MHz antenna and set up the software using the STM32CubeMX to broadcast at 915 MHz?
2025-01-13 10:03 AM - edited 2025-01-13 10:08 AM
Seems so ...from data:
Is your RF output circuit matching at these frequency ?
from ds :
from ds :
