Bluetooth module without pairing
  • May 16, 2024
  • 15 replies
  • 3472 views
actually, i'm searching some reference of Bluetooth module without pairing, i want that the Bluetooth module communicate directly without paring.
Can you give some references please ?
Andrew Neil
It's not going to be down to a specific module - it's the way you program/configure it.
Pairing isn't mandatory.
https://community.st.com/t5/stm32-mcus-wireless/wireless-peer-to-peer-communication-w-o-user-intervention/m-p/675426/highlight/true#M19103
ljmAuthor
Hello @Andrew Neil
Thanks for replying
So that mean BLE doesn't require pairing even for a first connection ( for the first time )?
Another question please, with your BLE Module can i connect at the some time to many other modules and collect data in the same time ?
Andrew Neil
Correct.
That depends on the module, and the application in/using it.
Plenty of modules are available which can do that. It requires more resources, so they won't be the cheapest ones...
