BLE Stack modify the RCC configuration
‎2024-04-27 10:31 AM - edited ‎2024-04-27 7:40 PM
HI,
I am developing my ble audio project with STM32WBA55G-DK1. I need use SAI interface as audio input interface. I have an annoying problem. I configure RCC before init ble stack. I choose use pll1rclk as system clock. But i call the BleStack_Init function to init ble stack which provide by ST, the register of RCC_CFGR1 changed from 0xF to 0x0, HSI16 becomes as system clock. I can't understank why the Ble stack do that。 If so that, does it mean that the maximum system clock can only be 16M when using Bluetooth function?
- Labels:
BLE
STM32WBA series
‎2024-05-30 7:29 AM - edited ‎2024-05-30 8:38 AM
Hello @Xiaojie
Could you send a .ioc file that may help us to reproduce this issue. I've tried to reproduce it on my side but is not possible.
Best Regards.
STTwo-32
Hello @Xiaojie
Best Regards.
STTwo-32
‎2024-05-30 6:45 PM
HI,
I known where change the RCC configuration. LINKLAYER_PLAT_RCOStartClbr and LINKLAYER_PLAT_RCOStopClbr call scm_setsystemclock,which willchange the RCC configuration.
It is related to RCO calibration。What is RCO?
