2025-01-08 7:21 AM
I try to use these two boards:
- X-NUCLEO-GFX01M2
- NUCLEO-G071RB
I managed to use TouchGFX Designer to do a simple exemple with two buttons.
But i can't have events while pressing buttons on screen. In buttonCallbackHandler() function, i have
no breakpoints at each press.
I follow instructions on this page:
https://support.touchgfx.com/academy/tutorials/tutorial-02
Do you have an idea for the callback no processing?
Thank you. Best regards,
2025-01-08 2:14 PM
I found the reason, this display is not a capacitive touch LCD.
The subject could be closed.
Thnak you.
2025-01-08 2:14 PM
Thnak you.
