Whether some recent updates have caused some problems
2020-04-01 7:30 AM
2020-04-06 1:27 AM
The 2x 429-disco does look strange, but it's not an issue i'm seeing here. I'm noticing you don't have a proper connection (red cloud) to the package server. Can you check your connection and try again?
The compilation errors are from FreeRTOS code - You may be using a compiler that is not supported by some version of FreeRTOS. Which ARM compiler did you select?
/Martin
2020-04-30 3:37 AM
Any update from you on this?
2020-05-01 11:39 PM
Hi Martin
I didn't make any updates.I know you have updates in the application template.
There is no cubemx flag to begin with.Since there has been a cubemx flag and this has been the case ever since.
I can easily download any UI template using PC,but can not download any UI template using application template.
If I download wrong, there may be an occasional display of these.
/korry
2020-05-01 11:53 PM
I'm sorry I went to deal with other business some time ago. The problem with The 2×f429disc no longer seems to exist.
