2019-05-19 06:29 AM
where could i find the the BMPFileLoader class menthioned in website ( https://touchgfx.zendesk.com/hc/en-us/articles/207460605-Dynamic-Bitmaps-Load-images-at-runtime)
it says,"The BMPFileLoader class used in the example can be found in the "dynamic_bitmap_example" provided with TouchGFX."
where is the example?how to download?
2019-05-20 01:17 AM
Hi @LMC,
The dynamic_bitmap_example was moved out of TouchGFX. Allow me to attach the files you're looking for,
2019-05-20 01:17 AM
2019-05-24 07:35 PM
Thank you very much!
2019-05-26 11:54 PM
You're welcome. I know the example is missing and as soon as we can prioritize it we'll add more of the "old" examples that haven't been "designerfied" yet.
/Martin
2019-06-12 07:46 PM
2019-06-12 10:11 PM
Okay, i'm not really sure i understand the underlying issue. Can you exemplify with screenshots and code?
/Martin
2019-06-12 10:15 PM
2019-06-13 12:56 AM
I have downloaded the application, and will try to read the code. Thanks.
2019-06-13 01:08 AM
Okay, let me know how you do.
