Where is BMPFileLoader?
JaHnu
I didn't find “dynamic_bitmap_example“ in TouchGFX
Martin KJELDSEN
Chief III
Hi @JaHnu​
A Dynamic Bitmap in TouchGFX is not necessarily just loading a BMP, dynamically. It means that you can modify a piece of memory at runtime and treat it as a Bitmap in TouchGFX. But, now that we're on the subject, you're right that the dynamic_bitmap_example from TouchGFX 4.8.0 has not made its way into the designer yet.
I've attached it here (based on 4.8.0).
/Martin
6 REPLIES 6
Martin KJELDSEN
Chief III
Hi @JaHnu​
/Martin
Thank you Martin KJELDSEN
You're welcome!
Iswarya
Missing lot of files.
This example is not maintained - I grabbed it from an old release. It should definitely be made into a UI template.
Are you able to get some inspiration from it?
