2019-02-12 7:27 AM
Hi All
I don't have all widgets in the TouchGFX Designer 4.10.0. For example Text area with wildcard is missing. Where do I found them?
Thank you
2019-02-12 10:59 PM
Hi @rzapp,
Not all widgets in TouchGFX are available through the designer. We're constantly adding more support for those (e.g. TextureMapper will be in the designer in 4.11.0).
As far as TextAreas are concerned, TextAreaWithWildcard is not a seperate widget. Go to the properties of the TextArea and look for "Add wildcard".
Hope this helps,
Best regards,
Martin
2019-02-12 10:59 PM
Hi @rzapp,
Hope this helps,
Best regards,
Martin
