Warning: This IP has no parameter to be configured.
FKafi.1
When i enable STM32-XCUBE-TOUCHGFX pack in my cubeMX software ; i have no parameter to configure but i got this warning : "This IP has no parameter to be configured" .
How should i solve this issue?
13 REPLIES 13
Yeah. It works.
And also CRC must be enabled.
Thank you.
I have tried many times but there is still the same warning. what can I do ?
Hi
Im facing the same problem and I uninstalled and then installed the CubeMx but the problem stands still !
whats the solution ?
and here is my .ioc file
We will try to answer your question on the other topic you created. I am just adding the link for future people facing this issue and finding only this topic.
