2015-01-05 04:52 PM
Hi guys, I need again a big help from you. I'm trying to use the STemWin software with STM32F4Discovery, without success for the moment. I followed these steps:
The display module is connected through FSMC and my driver for SSD1289 works perfectly but when adapted for STemWin, the program stucks at the function GUI_Init().
This is the SSD1289 code adapted:/*********************************************************************
* Portions COPYRIGHT 2014 STMicroelectronics *
* Portions SEGGER Microcontroller GmbH & Co. KG *
* Solutions for real time microcontroller applications *
* (c) 1996 - 2013 SEGGER Microcontroller GmbH & Co. KG *
* Internet: www.segger.com Support: support@segger.com *
** emWin V5.22 - Graphical user interface for embedded applications **
All Intellectual Property rights in the Software belongs to SEGGER.
emWin is protected by international copyright laws. Knowledge of the
source code may not be used to write a similar product. This file may
only be used in accordance with the following terms:
The software has been licensed to STMicroelectronics International
N.V. a Dutch company with a Swiss branch and its headquarters in Plan-
les-Ouates, Geneva, 39 Chemin du Champ des Filles, Switzerland for the
purposes of creating libraries for ARM Cortex-M-based 32-bit microcon_
troller products commercialized by Licensee only, sublicensed and dis_
tributed under the terms and conditions of the End User License Agree_
ment supplied by STMicroelectronics International N.V.
Full source code is available at: www.segger.com
We appreciate your understanding and fairness.
File : LCDConf.c
Purpose : Display controller configuration (single layer)
---------------------------END-OF-HEADER------------------------------
* @file LCDConf_stm3240g_eval.c
* @author MCD Application Team
* @version V1.1.2
* @date 28-January-2014
* @brief Driver for STM3240G-EVAL board LCD
* @attention
* Licensed under MCD-ST Liberty SW License Agreement V2, (the ''License'');
* You may not use this file except in compliance with the License.
* You may obtain a copy of the License at:
* http://www.st.com/software_license_agreement_liberty_v2
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an ''AS IS'' BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
#include ''GUI.h''
#include ''GUIDRV_FlexColor.h''
#include ''global_includes.h''
* Layer configuration (to be modified)
// Physical display size
#define XSIZE_PHYS 240
#define YSIZE_PHYS 320
* Configuration checking
#ifndef VXSIZE_PHYS
#define VXSIZE_PHYS XSIZE_PHYS
#endif
#ifndef VYSIZE_PHYS
#define VYSIZE_PHYS YSIZE_PHYS
#endif
#ifndef XSIZE_PHYS
#error Physical X size of display is not defined!
#endif
#ifndef YSIZE_PHYS
#error Physical Y size of display is not defined!
#endif
#ifndef GUICC_565
#error Color conversion not defined!
#endif
#ifndef GUIDRV_FLEXCOLOR
#error No display driver defined!
#endif
* Defines, sfrs
// COG interface register addr.
#define LCD_BASE ((uint32_t)(0x60000000 ))
#define LCD_REG_ADDRESS (*((volatile unsigned short *) 0x60000000))//(*(volatile U16*)LCD_BASE)
#define LCD_DATA_ADDRESS (*((volatile unsigned short *) 0x60020000))//(*(volatile U16*)(LCD_BASE + 0x00020000))
* Local functions
* LcdWriteReg
* Function description:
* Sets display register
static
void
LcdWriteReg(U16 Data) {
LCD_REG_ADDRESS = Data;
* LcdWriteData
* Writes a value to a display register
static
void
LcdWriteData(U16 Data) {
LCD_DATA_ADDRESS = Data;
* LcdWriteDataMultiple
* Writes multiple values to a display register.
static
void
LcdWriteDataMultiple(U16 * pData,
int
NumItems) {
while
(NumItems--) {
LCD_DATA_ADDRESS = *pData++;
* LcdReadDataMultiple
* Reads multiple values from a display register.
static
void
LcdReadDataMultiple(U16 * pData,
int
NumItems) {
while
(NumItems--) {
*pData++ = LCD_DATA_ADDRESS;
* Public functions
* LCD_X_Config
* Called during the initialization process in order to set up the
* display driver configuration.
void
LCD_X_Config(
void
GUI_DEVICE * pDevice;
CONFIG_FLEXCOLOR Config = {0};
GUI_PORT_API PortAPI = {0};
// Set display driver and color conversion
pDevice = GUI_DEVICE_CreateAndLink(GUIDRV_FLEXCOLOR, GUICC_565, 0, 0);
// Display driver configuration, required for Lin-driver
LCD_SetSizeEx (0, XSIZE_PHYS , YSIZE_PHYS);
LCD_SetVSizeEx(0, VXSIZE_PHYS, VYSIZE_PHYS);
// Orientation
Config.Orientation = GUI_SWAP_XY | GUI_MIRROR_Y;
GUIDRV_FlexColor_Config(pDevice, &Config);
// Set controller and operation mode
PortAPI.pfWrite16_A0 = LcdWriteReg;
PortAPI.pfWrite16_A1 = LcdWriteData;
PortAPI.pfWriteM16_A1 = LcdWriteDataMultiple;
PortAPI.pfReadM16_A1 = LcdReadDataMultiple;
GUIDRV_FlexColor_SetFunc(pDevice, &PortAPI, GUIDRV_FLEXCOLOR_F66702, GUIDRV_FLEXCOLOR_M16C0B16);
* LCD_X_DisplayDriver
* This function is called by the display driver for several purposes.
* To support the according task the routine needs to be adapted to
* the display controller. Please note that the commands marked with
* 'optional' are not cogently required and should only be adapted if
* the display controller supports these features.
* Parameter:
* LayerIndex - Index of layer to be configured
* Cmd - Please refer to the details in the switch statement below
* pData - Pointer to a LCD_X_DATA structure
* Return Value:
* < -1 - Error
* -1 - Command not handled
* 0 - Ok
int
LCD_X_DisplayDriver(unsigned LayerIndex, unsigned Cmd,
void
* pData) {
int
r;
void
) LayerIndex;
void
) pData;
switch
(Cmd) {
case
LCD_X_INITCONTROLLER: {
/* Already Done */
//SSD1289_Init();
return
0;
default
r = -1;
return
r;
/*************************** End of file ****************************/
Any ideas?
#ssd1289 #stm32f4 #stemwin
2015-01-15 02:57 AM
The SSD1289 LCD is supported by STemWin since 5.18 version. You have just need to configure the LCDConf file (by adding the basic write/read operation) and call the right controller in LCD_X_Config (for SSDD1289: GUIDRV_FLEXCOLOR_F66702)Keep us informed about your finding.Regards,Heisenberg.
