2020-03-16 07:39 AM
i installed TouchGFX Designer V4.13.0 and the other ST Tool under C:\Software\ST\...
If i start GFX Designer and select the STM32H7B3I-DK Board an a template UI i can tun it under the simulator but i can't program it to the Board.
The STM32CubeProgrammer was not found.
If i edit the makefile with the right part to the programmer the template will be prgrammed to the board but the screen is black.
My 2 Questions:
Thanks!
2020-03-17 06:13 AM
ok i install all ST Tools at their default installation path.
Unfortunately the UI Templates doesn't work. :-(
I thought that i can test it like describe here: https://touchgfx.zendesk.com/hc/en-us/articles/205561611-Step-2-Running-an-example-application-on-a-STM32-board
Where's my mistake?
