2022-07-17 05:53 PM
I was wondering what the TouchGFX porting process is like for development across different MCUs.
I'm thinking of starting development for a GUI on an STM32 Discovery Board, and then when the actual hardware gets produced, switch over to developing on that. I was wondering what the porting processes for that would entail.
It seems like you can easily port over a TouchGFX version on the same MCU. https://support.touchgfx.com/4.20/docs/miscellaneous/updating-to-a-new-touchgfx-version
But I was wondering if there was a similar process across different MCUs other than just re-generating the MCU specific code and then copy and pasting the user code into the new project.
Thanks!
2022-07-18 01:26 AM
Hello DOkaz.1,
If by user code you mean TouchGFX code, then it's super easy to reuse it on different boards.
In TouchGFX Designer, we have a functionality to "import GUI" which will copy the GUI and all associated user code from an older project to your new one.
/Osman
2022-07-18 01:26 AM
Hello DOkaz.1,
/Osman
2022-07-19 08:53 PM
yes, cool, thanks!
