TouchGFX 4.15.0 Designer -- Shape's Alpha level sometimes not working.
scottSD
Lead
I saw this bug earlier today. I am not sure how recreatable it is....
In the TouchGFX Designer (4.15.0), I adjusted the alpha level of a shape and it correctly went to that level of transparency. Sometime later that shape was solid (no transparency) and any adjusting of the alpha level did not change the visible alpha of the shape in the Designer.
I closed down the Designer and reopened it and the shape's alpha level in the Designer was correct.
Alexandre RENOUX
Principal
I tried and I cannot reproduce on my side.
Could you provide the exact steps you did if you happen to encounter it again ?
Thank you for reporting it ^^
/Alexandre
@Alexandre RENOUX​
Thanks for replying back.
I am unsure of the exact steps and couldn't recreate it. Sorry I cannot provide more. As software developer, I understand any frustration you may have with my reporting something and not being able to provide steps to recreate it.
If I see it again, I will comment back here with any steps I can provide to recreate it.
