Touch GFX Errors while launching simulator and generating code.
FGREM.9
Hy everybody,
I'm new on TouchGFX and after installing it, I opened a sample program and when I want to launch the simulator or generate the code, I get error messages.
Did I need to make some configuration to get it work?
Thanks in advance for reply,
Regards.
cameronf
Can you post the errors? People will likely to be able resolve issues related to a specific error.
Martin KJELDSEN
Chief III
Hi @FGREM.9​,
Did you manage to solve this? If it says "unable to generate code" try removing the "PostGenerateCommand" command in the .touchgfx file or replace it with something like "echo test" - Designer will complain if empty (but not fail).
