Touch GFX debug issue
jijomathew
I have integrated touch GFX with quad SPI, and images are stored in external flash, in debug mode the code is getting stuck inside the Hal Delay. What is the root cause for this, if I disable the external loader the Hal delay does not get stuck.
GaetanGodart
Hello @jijomathew ,
Have you bene able to fix your previous issue ?
Can you share the call stack like you did in your previous issue so we can all investigate where it is stuck exactly?
It does sound like an issue with the external loader exclusively, have you been able to make it work previously?
Gaetan Godart
Software engineer at ST (TouchGFX)
  • Yes i was able to resolve the issue, last time there was a mismatch in the project configuration which I was trying to link,
