2025-02-21 03:58 AM
I have integrated touch GFX with quad SPI, and images are stored in external flash, in debug mode the code is getting stuck inside the Hal Delay. What is the root cause for this, if I disable the external loader the Hal delay does not get stuck.
2025-02-21 05:32 AM
Hello @jijomathew ,
Have you bene able to fix your previous issue ?
Can you share the call stack like you did in your previous issue so we can all investigate where it is stuck exactly?
It does sound like an issue with the external loader exclusively, have you been able to make it work previously?
2025-02-21 10:34 AM
