STM32F746G DISCO, TouchGFX
‎2020-11-03 2:36 AM
Hello
Are the screen buttons visible in the main.c function? Do they need to be communicated in some way?
Best regerds
Andrzej
STM32F7 Series
TouchGFX
‎2020-11-18 3:05 AM
​Handlers for Buttons in TouchGFX are usually activated through touch on a physical display. It sounds like what you need to do is call a function in your model from the view that has the button handler, to start the calculation somewhere in the backend.
/Martin
‎2020-11-18 1:22 AM
What do you mean by "screen buttons"? TouchGFX buttons? If so, no they're not visible from here and i'm not sure why you'd want them visible there. If you want to do something based on input from the rest of the system i you can create another task and send a message to the main gui-thread which can communicate with the buttons.
Please check out support.touchgfx.com to see if you can find information on interfacing with your backend. I did a webinar on it once.
/Martin
‎2020-11-18 2:24 AM
Yes TouchGFX buttons. The button from TouchGFX is supposed to start the calculation.
I will work and inform.
best regards
‎2020-11-18 3:05 AM
/Martin
‎2020-11-18 3:54 AM
Hi.
I thought so. If I do it, I will write it.
Thank you.
best regards
Andrzej
‎2020-11-18 4:06 AM
​Great, let me know!
