STM32F746G-DISCO, STM32CubeIDE 1.4.0, GFX 4.14.0 TUTORIAL https://www.youtube.com/watch?v=12KXreXaLp0&t=3s
AD�?b
Compiles OK.
I set the GFX screen to blue.
Loads the black screen into the STM32F746G-DISCO.
Why?
Yes I use.
I found the cause. McAfee Protection!
Thank you
Alexandre RENOUX
Principal
Did you try with the F746G-DISCO Application Template in the Designer ? We create these Application Templates for users to start off with a working project.
Also, you can try to compare the two projects and see if there is any difference.
/Alexandre
Yes I use.
Thank you
