STM32F4 Discovery - DCMI does not call HAL_DCMI_FrameEventCallback Camera : ov9655 I am using CubeMX to generate the code
Junaid
Hello There,
I am trying to connect OV9655 camera (WaveShare) module with STm32f4 discovery board. After generating files from CubeMX and importing ov9655 drivers (ov9655.h & ov9655.c) I am able to get HAL_DCMI_LineEventCallback and HAL_DCMI_VsyncEventCallback event but not able to get HAL_DCMI_FrameEventCallback.
I am using Snapshot mode
 BSP_CAMERA_Init(RESOLUTION_R320x240);
 HAL_Delay(1000);
HAL_DCMI_Start_DMA(&hdcmi, DCMI_MODE_SNAPSHOT, (uint32_t)CAMERA_FRAME_BUFFER, GetSize((uint8_t *)RESOLUTION_R320x240));
Please suggest where I am making mistake. Also please let me if any further info needed.
DMA Initialization
 * Enable DMA controller clock
static void MX_DMA_Init(void)
 /* DMA controller clock enable */
 __HAL_RCC_DMA2_CLK_ENABLE();
 /* DMA interrupt init */
 /* DMA2_Stream1_IRQn interrupt configuration */
 HAL_NVIC_SetPriority(DMA2_Stream1_IRQn, 0, 0);
 HAL_NVIC_EnableIRQ(DMA2_Stream1_IRQn);
 * @brief DCMI Initialization Function
 * @param None
 * @retval None
static void MX_DCMI_Init(void)
 /* USER CODE BEGIN DCMI_Init 0 */
 /* USER CODE END DCMI_Init 0 */
 /* USER CODE BEGIN DCMI_Init 1 */
 /* USER CODE END DCMI_Init 1 */
 hdcmi.Instance = DCMI;
 hdcmi.Init.SynchroMode = DCMI_SYNCHRO_HARDWARE;
 hdcmi.Init.PCKPolarity = DCMI_PCKPOLARITY_FALLING;
 hdcmi.Init.VSPolarity = DCMI_VSPOLARITY_LOW;
 hdcmi.Init.HSPolarity = DCMI_HSPOLARITY_LOW;
 hdcmi.Init.CaptureRate = DCMI_CR_ALL_FRAME;
 hdcmi.Init.ExtendedDataMode = DCMI_EXTEND_DATA_8B;
 hdcmi.Init.JPEGMode = DCMI_JPEG_DISABLE;
 if (HAL_DCMI_Init(&hdcmi) != HAL_OK)
  Error_Handler();
16 REPLIES 16
Hi. You must initialize DMA before calling HAL_DCMI_Start_DMA. Because HAL_DCMI_FrameEventCallback rise by setting DCMI_IT_FRAME bit. (from function DCMI_DMAXferCplt, file stm32f4xx_hal_dcmi.c). Check example for STM324xG_EVAL in your local CubeMX repository.
Junaid
Thank you very much for your reply. I have already did so. Please check the full main function :
int main(void)
 /* USER CODE BEGIN 1 */
 /* USER CODE END 1 */
 HAL_Init();
 /* USER CODE BEGIN Init */
 /* USER CODE END Init */
 SystemClock_Config();
 /* USER CODE BEGIN SysInit */
 //MaxInitDMA1();
 /* USER CODE END SysInit */
 MX_GPIO_Init();
 MX_DMA_Init();
 MX_I2C1_Init();
 MX_USART1_UART_Init();
 MX_CRC_Init();
 MX_DCMI_Init();
 /* USER CODE BEGIN 2 */
 HAL_Delay(1000);
 //HAL_DCMI_Start_DMA(&hdcmi, DCMI_MODE_SNAPSHOT, frame_buffer, GetSize((uint8_t *)CAMERA_R160x120));
 /* USER CODE END 2 */
 /* Infinite loop */
 /* USER CODE BEGIN WHILE */
 while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
 //HAL_DCMI_Start_DMA(&hdcmi, DCMI_MODE_SNAPSHOT, (uint32_t)CAMERA_FRAME_BUFFER, GetSize((uint8_t *)CAMERA_R160x120));
 /* USER CODE END 3 */
Did you properly initialize DMA for DCMI data fetching? Share you CubeMX file.
Junaid
attached
Configuration for DMA from STM32F4xG_Eval Example for DCMI Snapshot Mode
 /*** Configure the DMA streams ***/
 /* Configure the DMA handler for Transmission process */
 hdma.Init.Channel       = DMA_CHANNEL_1;
 hdma.Init.Direction      = DMA_PERIPH_TO_MEMORY;
 hdma.Init.PeriphInc      = DMA_PINC_DISABLE;
 hdma.Init.MemInc       = DMA_MINC_ENABLE;
 hdma.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
 hdma.Init.MemDataAlignment  = DMA_MDATAALIGN_WORD;
 hdma.Init.Mode        = DMA_CIRCULAR;
 hdma.Init.Priority      = DMA_PRIORITY_HIGH;
 hdma.Init.FIFOMode      = DMA_FIFOMODE_DISABLE;
 hdma.Init.FIFOThreshold    = DMA_FIFO_THRESHOLD_FULL;
 hdma.Init.MemBurst      = DMA_MBURST_SINGLE;
 hdma.Init.PeriphBurst     = DMA_PBURST_SINGLE;
 hdma.Instance = DMA2_Stream1;
DMA Mode is CIRCULAR.
Junaid
Thanks. I will change the setting from Normal to Circular & test. Will revert with results. Thanks for your prompt responses.
Refer to this document Digital camera interface (DCMI) for STM32 MCUs
"In snapshot mode: the DMA must ensure the transfer of one frame (image) from the DCMI to the desired memory:
– If the image size in words does not exceed 65535, the stream can be configured in normal mode. For more detailed description of this mode, refer to Section 4.4.6: Normal mode for low resolution in snapshot capture"
So it must works in normal mode. Maybe problem with CAMERA_FRAME_BUFFER location. Where you place it?
Junaid
Memory location : 0x64000000
This address mapped to external NOR/PSRAM. You didn`t initialize SRAM in your main.
