STemWin - IAR inconsistent wchar_t size warnings
Pavel A.
I'm building something with STemWin object libraries v 5.28 or 5.32 for IAR (STemWin532_CM7_IAR.a) and get warnings:
Warning[Lt009]: Inconsistent wchar_t size
      GUI_BMP.o(STemWin532_CM7_IAR.a) and 158 other objects in STemWin532_CM7_IAR.a have wchar_t size 16 bits
      aes.o and NNN other objects, some of them in ... and 73 other libraries have wchar_t size 32 bits
The release notes for IAR states that
<QUOTE>
In EWARM version 7.80 and earlier, the size of wchar_t was 2 bytes wide and the runtime attribute was set accordingly.
In EWARM version 8.10 and later, wchar_t is 4 bytes wide.
</QUOTE>
Can ST provide the libraries for IAR built with a modern compiler version, please ?
0 REPLIES 0
