2019-09-05 02:08 AM
I ported "Model UI TouchGFX Demo 1 " on my board (WaveShare Open746I).
Screen resolution increases to 1024x600 16BPP.
On the target and also slightly on the simulatorIn in the Graph screen transiton of SlideMenu it's very slow.
if I remove points and area setting the transition is less slow, until it becomes normal by removing the two graphs.
What this slowdown is due to ?
Also.
The addition of values to the graph is done in GraphView::handleTickEvent. How often GraphView::handleTickEvent is recalled? Depends on the screen resolution?
//Antonello
2019-09-17 03:38 AM
2022-11-21 12:02 AM
Hi, how did you make background dots (thought white ) in your screen?
Did you do it by major gridline?
