2024-02-22 11:32 AM
When a condition is validated, for example clicking in the middle of the scroll whell (flag == 1), how to change page, I can't do it? I've tried several things but I can't find anything explicit and clear in the posts or tutorials.
2024-02-22 12:08 PM - edited 2024-02-22 12:09 PM
Hello
Just add to some of your screen interactions for changing screen - Screen x for all necessary screens. Its not needed to put any trigger to those interaction.
Then generate code and check generated function names from FrontendApplicationBase.cpp file. Then just call those functions from your switch-case structure.
Check my earlier answer here, maybe its enough clear:
Br JTP
Hello
Br JTP
2024-02-22 12:57 PM - edited 2024-02-22 12:58 PM
Many thanks 😀
