SD issue using STM32H747I-DISCO when writing floats converted to strings using snprintf()
2023-05-30 3:15 AM - edited 2023-11-20 4:22 AM
Dear all, I have an issue that only impacts floats and doubles when converted to strings using snprintf which are then stored to an SD card. The save is run in a dedicated task using TouchGFX and I am disabling dcache before and re-enabling after saving. If I write standard strings or integers (converted to strings via snprintf), there is no issue, the task exits normally and returns to the save screen. If I attempt to save any float or a double, the program has a Memory Management fault (attached). However, the data has been written to the card successfully. Would anyone be able to point me to a solution?
- Labels:
SDIO-SDMMC
STM32H7 Series
TouchGFX
2023-06-13 4:10 AM
Hello @JSext.1,
Could you please screenshot 0xE000ED28?
