Screenshot feature with TouchGFX designer tool
BGuth.1
I am wondering if it is possible to implement a screenshot feature with TouchGFX. I want to capture the screen, in jpg or bmp format, and dump the image to serial for later viewing on computer.
ktrofimo
Senior III
There is nothing to do with TouchGFX. It just helps you to draw a picture on your screen by putting data in corresponding memory area. You have​ all data you need in the screen RAM (framebuffer) - just dump it to your serial.
If you need a BMP or JPG - I would suggest to write a converter on a PC rather than on MCU​
Billy OWEN
Hi @BGuth.1​
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Billy
