2020-11-16 8:07 AM
Hello
I am using graph on STM32H747I-DISCO. Running simulation is ok, like having the sine wave on it but when I click "Run Target" I get this error...
Run Target
Generate
Done
Generate Assets
make -f simulator/gcc/Makefile assets -j8
Converting images
Reading ./application.config
Done
Post Generate
touchgfx update_project --project-file=simulator/msvs/Application.vcxproj && touchgfx update_project --project-file=../EWARM/TouchGFX.ewp
Done
Compile
make -f ../gcc/Makefile -j8
STM32CubeProgrammer is placed in Program Files
Converting images
Reading TouchGFX/application.config
Linking TouchGFX/build/bin/target.elf
Producing additional output formats...
target.hex - Combined internal+external hex
intflash.elf - Internal flash, elf debug
intflash.hex - Internal flash, hex
extflash.bin - External flash, binary
Done
Flash
make -f ../gcc/Makefile -j8 flash
Converting images
STM32CubeProgrammer v2.5.0
ST-LINK SN : 003100173137511539383538
ST-LINK FW : V3J7M2
Board : STM32H747I-DISCO
Voltage : 3.23V
Error: ST-LINK error (DEV_TARGET_NOT_HALTED)
2nd connect tentative with a lower frequency (8MHz)
ST-LINK FW : V3J7M2
Voltage : 3.23V
gcc/Makefile:334: recipe for target '_extflash_' failed
make[1]: *** [_extflash_] Error 1
make: *** [flash] Error 2
../gcc/Makefile:50: recipe for target 'flash' failed
Failed
Failed
2020-12-08 7:01 AM
Yes, it is working on 2.5.0, see my previous answer (at the end)...
2020-11-16 8:41 AM
Any demo would display the same error...
2020-11-19 12:37 AM
I use on another PC with cubeprogrammer 2.6.0, here is different error.
Run Target
Generate
Done
Generate Assets
Converting images
Done
Post Generate
Done
Compile
Converting images
Done
Flash
Converting images
STM32CubeProgrammer v2.6.0
Error: External loader C:\Program cannot be loaded.
Error: External loader Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin\ExternalLoader\MT25TL01G_STM32H747I-DISCO.stldr cannot be loaded.
ST-LINK FW : V3J7M2
Voltage : 3.24V
SWD freq : 24000 KHz
Connect mode: Normal
Reset mode : Software reset
Device ID : 0x450
Revision ID : Rev V
Device name : STM32H7xx
Flash size : 2 MBytes
Device type : MCU
Device CPU : Cortex-M7/M4
Memory Programming ...
Opening and parsing file: target.hex
File : target.hex
Address : 0x08000000
Erasing internal memory sector 0
Erasing memory corresponding to segment 1:
Erasing internal memory sectors [0 1]
Erasing memory corresponding to segment 2:
Download in Progress:
±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± 0%
ÛÛÛÛÛÛÛÛÛÛ 20%
Error: failed to download Segment[2]
Error: failed to download the File
Hard reset is performed
Failed
Failedprevious error using another PC with cubeprogrammer 2.5.0 seems to be ok now.
2020-12-08 4:31 AM
@victagayun I am also having exactly same problem when trying with STM32CubeProgrammer V2.6.0 on STM32H747i-Disco board. Can someone please provide any solution.
Run Target
Generate
Done
Generate Assets
Converting images
Done
Post Generate
Done
Compile
Converting images
Done
Flash
Converting images
ST-LINK SN : 002B00453137510D39383538
ST-LINK FW : V3J3M2
Board : STM32H747I-DK
Voltage : 3.23V
Device ID : 0x450
Revision ID : Rev V
Device type : MCU
File : target.hex
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ 100%
Failed
Failed
2020-12-08 5:31 AM
Could you download and try STM32CubeProgrammer 2.5 ? There are issues with the latest version 2.6 so we recommend to not use 2.6 until the next patch release.
/Romain
2020-12-08 7:01 AM
