Request/Idea: TouchGFX library built with Clang.
JureL
Hi @Romain DIELEMAN, @Osman SOYKURT@LouisB
We are using TouchGFX library, now for almost 5 years. We are very satisfied with the product and its's regular updates/improvments and new featuers. However we have one limitation: the current library does not officially support the Clang compiler. We are using SEGGER compiler - Clang for our projects so I needed to do some workarounds for current gcc library to got it working with it. Would it be possible to add support for Clang compiler in future releases? This way it would also be directly compatible with the SEGGER compiler and no other workarounds would be required.
I am looking forward to your positive response and the continued evolution of the TouchGFX library.
2 REPLIES 2
LouisB
Hello @JureL ,
Thanks for suggestion, I will bring that idea to team.
Best regards,
Louis BOUDO
Hi @Romain DIELEMAN@Osman SOYKURT@LouisB
Did you bring that idea to the touchgfx team ?
Can we expect library built with clang in future release?
Thank you.
Best regards, Jure
