problem with touchgfx and iar in cubemx 6
‎2020-09-16 03:16 AM
hello
i use cubemx6 and iar
i create project with touchgfx in cubemx 6 and generate code in touchgfx file
When I compile there, there are several errors if this was not the case in the previous version of cube (v5).
how to resolve this?
STM32CubeMX
TouchGFX
‎2020-09-17 02:59 AM
Please list all the steps you did along with the errors you encountered, in order for us to be able to answer.
/Alexandre
‎2020-09-17 11:56 PM
1-Config LTDC
2- Config FMC
3-Select Touchgfx 4.14 from additonal software
4-Config Touchgfx Software (Select LTDC Interface and ADD, DMA2D , ...)
5-Config Clock
6-Generate code for IAR
7-Generate code in Touchgfx
in the cubemx 5.6 create midlewares Folder and add touchgfx_core.a to program and in version 6 of cube does not create and add this folder and touchgfx_core.a to project
‎2020-09-18 04:51 AM
What board/MCU are you configuring ? What compilation errors do you have ?
/Alexandre
‎2020-09-18 07:36 AM
when i use'd old version of cube (5.6) I do not have these errors.
my board is f429 and f743 custom.
‎2020-09-18 08:58 AM
It looks like your files are not correctly referenced in your IAR project.
Are you sure you clicked on "Generate code" in TouchGFX Designer before building your project ?
Why did you need to create middlewares Folder and add touchgfx_core.a ? I don't believe this is necessary.
/Alexandre
‎2020-09-18 09:40 PM
1-It looks like your files are not correctly referenced in your IAR project
Yes but in cube v5.6 I did not have these errors.
2-Are you sure you clicked on "Generate code" in TouchGFX Designer before building your project ?
Yes, I build another project And I did.
3-Why did you need to create middlewares Folder and add touchgfx_core.a ? I don't believe this is necessary.
In version 5.6 this folder is created and the touchgfx_core.a is added.
I think I have an error because these folders are not added
‎2020-09-21 01:24 AM
Could you enclose your .ioc file to see if I have the same issue when generating code ?
/Alexandre
