Potential Bug? : Build Error when using TouchGFX and MSVC Simulator .sln interchangeably
‎2021-06-04 12:59 AM
Steps:
- Use TouchGFX Designer to setup some GUI e.g. dynamic graph and generate the code then run simulation, make sure it is ok
- Open the MSVC simulator. Made some modification on the code or add additional cpp/hpp file into project. Build in MSVC make sure it is ok
- Switch again to TouchGFX Designer which might prompt you to accept external change. Click ok then generate the code and run simulator again -> build fail.
I notice in the code suddently the dynamic graph of the element area and element line instance were gone. As work around I needed to delete and create again the elemenet area and element line in TouchGFX Designer.
Following is the build error log snippet:
Run Simulator
Generate
Wrote generated/gui_generated/include/gui_generated/containers/CurveViewBase.hpp
Wrote generated/gui_generated/src/containers/CurveViewBase.cpp
Done
Generate Assets
make -f simulator/gcc/Makefile assets -j8
Reading ./application.config
Done
Post Generate
touchgfx update_project --project-file=simulator/msvs/Application.vcxproj
Done
Post Generate Target
touchgfx update_project --project-file=../STM32F769I_DISCO.ioc --platform=m7
Done
Compile
make -f simulator/gcc/Makefile -j8
Compiling gui/src/home_screen/HomeView.cpp
Compiling gui/src/home_screen/HomePresenter.cpp
Compiling gui/src/containers/CurveView.cpp
Compiling gui/src/model/SystemIfc.cpp
Compiling gui/src/model/Model.cpp
Compiling generated/gui_generated/src/home_screen/HomeViewBase.cpp
Compiling generated/gui_generated/src/containers/CurveViewBase.cpp
Compiling generated/gui_generated/src/common/FrontendApplicationBase.cpp
Compiling generated/simulator/src/mainBase.cpp
Compiling simulator/main.cpp
In file included from gui/include/gui/containers/CurveView.hpp:4:0,
from gui/include/gui/home_screen/HomeView.hpp:4,
from gui/src/home_screen/HomeView.cpp:1:
generated/gui_generated/include/gui_generated/containers/CurveViewBase.hpp:59:15: error: using-declaration for non-member at class scope
touchgfx::GraphElementArea ;
generated/gui_generated/include/gui_generated/containers/CurveViewBase.hpp:61:15: error: using-declaration for non-member at class scope
touchgfx::GraphElementLine ;
TouchGFX
‎2021-06-04 10:03 AM
Maybe in point 2 you edit some files , that is generated and isnt designed to edit. Place your code in GUI files not in generated... Generated files is always overwrited in point 3
‎2021-06-04 7:38 PM
Thank you @MM..1​ for the response but I did put it in gui/ folder. I am well aware not to touch the generated code part or folder :)
‎2021-06-13 5:01 AM
Any update to this issue please? This is getting annoying as I have to do work around to resolve the issue on regular basis
‎2022-01-26 2:15 AM
Hi @BParh.1​
Were you to able to solve the issue, has i am facing the same issue for gernerated GUI.
if you have a solution for the above please do guide me also.
With Regards
Lakshminarayana
‎2022-01-26 6:40 PM
Hi @LKade.1​ ,
The issue resolve but I did not how :). I just made series of seems unrelated changes, but these two probably the most likely resolve it:
- Upgrade my TouchGFX Designer from v4.16 to v.47. May be just consider upgrade to latest, I think there is newer version.
- I change the dynamic graph widget from custom container to directly insert it in screen level. Or vice versa, I forgot which one,maybe you could try both.
Please try and let me know how it goes, all the best!
