Please advise on using TextArea Set text interaction to dynamically set text.
ksale.1
Please note the interaction below trying to update text using the value in the buffer (not working)
Yoann KLEIN
Hello @ksale.1​ ,
Why not simply use Wildcards for displaying your value in the TextArea ?
That could be way more easy and you would be able to still use the Unicode::snprintf() method to achieve it.
/Yoann
Yoann KLEIN
ksale.1
I've achieved it programmatically in handleTickEvent()
void Screen1View::handleTickEvent()
	boxProgress1.setValue(flow);
	Unicode::snprintf(textArea1Buffer, TEXTAREA1_SIZE,"%u", flow);
	textArea1.invalidate();
can set text do the same?
Yoann KLEIN
Hello @ksale.1​ ,
/Yoann
Yoann KLEIN
