2023-09-01 10:44 AM
[STM32CubeMx 6.8.0 / TouchGfx 4.22]
Hi all,
I am trying to configure the LTDC as TouchGfx application tick source but the CubeMX won't let me even if the LTDC is enabled.
Any ideas? Is there anything else that I should check?
I have already working code from other projects that I could manually integrate but then every time we regenerate the code it will be overwritten.
Thanks,
2023-09-01 11:07 AM
How silly of me. I forgot to select LTDC as display Interface.
I guess it's time to power-off the computer 🙂
2023-09-01 11:03 AM
Hello @CMars.1
Can you provide more information about your configurations, the board you are using,...
Best regards.
II
2023-09-01 11:07 AM
