MX_TouchGFX_Init(); call and implementation are not the same type.
‎2022-04-14 11:57 AM
I have a build error where the call to MX_TouchGFX_Init(); in main.c (generated by Cube MX) is different than the one in app_touchgfx.h UINT MX_TouchGFX_Init(VOID *memory_ptr);, also generated by CubeMX
I am using TouchGFX 4.19.1 in Stm32CubeIDE 1.9
Did anybody ran into that? Any suggestion?
build console output:
../Core/Src/main.c: In function 'main':
../Core/Src/main.c:135:3: error: too few arguments to function 'MX_TouchGFX_Init'
135 | MX_TouchGFX_Init();
In file included from ../Core/Src/main.c:29:
../TouchGFX/App/app_touchgfx.h:45:6: note: declared here
45 | UINT MX_TouchGFX_Init(VOID *memory_ptr);
make[1]: *** [Core/Src/subdir.mk:59: Core/Src/main.o] Error 1
STM32CubeIDE
TouchGFX
‎2022-04-19 1:56 AM
Hello @SMalo.1​ ,
Can you please provide more information ?
- Which version of CubeMX are you using ?
- Are you using ThreadX OS in your project ?
- Have you already generated code both in CubeMX and TouchGFXDesigner ?
Thanks,
/Yoann
‎2022-04-19 5:30 AM
Hello Yoan,
I am using stm32CubeIDE 1.9.0 with Cube MX 6.5.0.20220251
We do indeed use ThreadX in our project (AzureRTOS H7.2.0.0_M7)
No, I have never got CubeMX and TouchGFX Designer to work, we did use TouchGFX Designer to generate some code last year (without STM32CubeIDE) but this was using a Disco (STM32H747) as a target. What I am trying to do now is to use the same STM32H747 as a target, but I tell Cube MX that this is a generic STM32H747 board (I wanted to get that to work before I start on our own hardware, to validate the tools).
‎2022-04-19 5:34 AM
Adding some information that I think might be relevant:
‎2022-05-04 12:05 PM
Any new on this.
We have the same error
MX - 6.5.0.2022.2251913
Using ThreadX OS
Have generated code from Designer and MX
Stefan
‎2025-04-26 8:23 AM
Also have same problem here
‎2025-04-28 5:03 AM
Hello @SMalo.1 ,
Maybe only one is re-generated when you click on "generate code". You could try to delete the generated files and re-generate.
If this doesn't work, I would advise to update your TouchGFX and STM32CubeMX software.
Software engineer at ST (TouchGFX)
