Multiple graphs in swipe container
MSecr.1
When I put more graphs in a swipe container on distinct pages and try to make a swipe on the graph area, nothing happens, when i do the swipe out of the graph area, it goes to the next page. Does anybody know how can i solve this problem ?
5 REPLIES 5
ktrofimo
Senior III
The problem is that Graph widget takes all gestures for itself. This is known problem and I have seen solutions on the net. The Idea was to take control over gestures and dispatch them properly.​
yeah, thanks, i already integrated this feature, i'll leave the code below
MSecr.1
code for swiping withing two graphs:
void GraphsView::handleClickEvent(const ClickEvent& evt)
  bool tempGraphAreaClicked = false;
  bool humGraphAreaClicked = false;
  if(TempGraph.getAbsoluteRect().intersect(evt.getX(), evt.getY()))
    tempGraphAreaClicked = true;
  else if(HumGraph.getAbsoluteRect().intersect(evt.getX(), evt.getY()))
    humGraphAreaClicked = true;
  // Click Event occurred
  if (evt.getType() == ClickEvent::PRESSED)
    if(tempGraphAreaClicked)
      // Click Event occurred within the graph
      clickStatus = ClickStatus::CLICKED;
    else if(humGraphAreaClicked)
    GraphsViewBase::handleClickEvent(evt); // act normally
  else if (evt.getType() == ClickEvent::RELEASED)
    if(clickStatus == ClickStatus::CLICK_DRAGGING)
      SwipeArea.handleClickEvent(evt);
    else
      // Not dragging, allow passing the event to the graph
    clickStatus = ClickStatus::RELEASED;
void GraphsView::handleDragEvent(const DragEvent& evt)
  bool dragIntersect = false;
  if((TempGraph.getAbsoluteRect().intersect(evt.getOldX(), evt.getOldY())) ||
    ( HumGraph.getAbsoluteRect().intersect(evt.getOldX(), evt.getOldY())))
    dragIntersect = true;
  if(dragIntersect)
    // Drag occurred within a graph
    if(abs(evt.getDeltaX()) > 2 && clickStatus == ClickStatus::CLICKED)
      // We are now dragging, cancel any graph touch by creating a new click event
      // and forwarding it to the rest of the view
      ClickEvent cancelEvt(ClickEvent::CANCEL, evt.getOldX(), evt.getOldY(), 1);
      GraphsViewBase::handleClickEvent(cancelEvt);
      clickStatus = ClickStatus::CLICK_DRAGGING;
    // We are dragging, forward drag events to swipe container only
    SwipeArea.handleDragEvent(evt);
  else
    // No dragging within a graph occured, act normally
    GraphsViewBase::handleDragEvent(evt);
void GraphsView::handleGestureEvent(const GestureEvent& evt)
    // We are dragging, forward gesture events to swipe container only
    SwipeArea.handleGestureEvent(evt);
  else
    GraphsViewBase::handleGestureEvent(evt);
MSecr.1
Declare those in header file
  void handleClickEvent(const ClickEvent& evt);
  void handleDragEvent(const DragEvent& evt);
  void handleGestureEvent(const GestureEvent& evt);
  enum class ClickStatus {
    RELEASED,
    CLICKED,
    CLICK_DRAGGING
  ClickStatus clickStatus;
