2020-04-06 01:39 AM
When Microsoft excel 2016 opens texts.xlsx, it will report some error. If I accept corrections and save the file, the designer can not recognize the file.
the text resource accumulates more and more, I must re-order the content. Which version or what other software should I use to modify the texts.xlsx.
2020-04-06 05:09 AM
however, this xlsx file is generated and updated by designer version 4.13. I have using it for several month.
After I checked some old demo projects, maybe:
if the project is created by older 4.12, even if updated by 4.13, it is ok
if the project is created by current 4.13, the problem occurs.
I have created a simplest new demo just now, the same problem occurs.
2020-04-06 05:50 AM
Based on previous check result, I solved it this way.
Copy an old texts.xlsx file from older 4.12 version, delete content in sheets, paste new content from current xlsx file, Save it. OK.
NOTE, table column order is different between version 4.12 and 4.13. so copy colums one by one.
hahaha
thank you, Martin.
2020-04-06 05:59 AM
This just sounds so strange.
/Martin
