STM32H7B3I-DK. Example projects show only a blank screen. If I download the hex file from ST for the built in example a display works fine. Something TouchGFX is doing must be incorrect. I'm not making any changes to the generated code.
JWalt.1
Martin KJELDSEN
Chief III
Did you do any debugging? Is the application running? Are you hitting setupScreen() in your views?
/Martin
