memory limit question
yu_jay
There was an issue where the screen froze due to too many packages. Is there a way in TouchGFX to check the memory limit for a screen and the amount of memory each package uses to evaluate the number of packages that can be used?
LouisB
Hello @yu_jay ,
I dont fully understand the question, what do you mean by "package" ? And you are running on target or in the simulator ?
Best regards,
Louis B.
Louis BOUDO
  1. In this context, does "package" mean how many toolkits are used in a single screen before causing errors?
  2. Under what conditions could the attached error occur?
